4.88 gears versus 5.13 for 4 door auto jk
Old 06-22-2011, 03:43 PM
jk2010mi's Avatar
Default 4.88 gears versus 5.13 for 4 door auto jk
I searched for a quick answer to my question, but good not find one. Which gearing would be better for an auto jk if I go to 35inch tires from 33 inch tires - 4.88 or 5.13? I currently have 3.73 gears. I have been told 4.88 is good, but is 5.13 better?
Old 06-22-2011, 03:48 PM
aermotor's Avatar
I'm pretty sure the consensus is 5.13s with an auto. 4.88s just aren't enough.
Old 06-22-2011, 03:57 PM
ScottW's Avatar
I will be putting 35's on my Jeep and regearing to 5.13.
Old 06-22-2011, 04:43 PM
StevieRay's Avatar
I have 35's and have had my 4.88's for about 30,000 miles now (with an auto). For me, I wanted to get the RPM's close to what was stock so that I don't wreck the gas mileage. I don't regret it at all.
Old 06-22-2011, 05:19 PM
nthinuf's Avatar
5.38's !!
If so I would like to know what your rpm is at 70mph? I'm curious how close my math is. From what I came up with this is very close to stock 32's with 4:10's about 200RPM.
Did you notice the RPM charts a few posts above yours? They are also in the drivetrain section of the faq's. Assuming you use the actual measured tire height and not the mfg's spec, they are pretty accurate.
This thread is a good read also. Start with post #33.
https://www.jk-forum.com/forums/show...=1#post2147185
Old 06-22-2011, 08:35 PM
archijeff's Avatar
4:88 with 35's are closer to stock ratio. But all depends on what your re-gearing for. Do you pull anything?
Old 06-23-2011, 03:12 AM
StevieRay's Avatar
Yes, I have a 5'X10' utility trailer and haul firewood (and other stuff) with it. I only use it every now and then but it does fine with it.
I'll check the RPM's at 70 this morning on the way to work. I know the chart is up there so we can see how close it is.
Old 06-23-2011, 03:14 AM
StevieRay's Avatar
Originally Posted by ukie jk
I'm curious, was this a Rubicon with 4:10's? Have you recalibrated your speedo? If so I would like to know what your rpm is at 70mph? I'm curious how close my math is. From what I came up with this is very close to stock 32's with 4:10's about 200RPM.
Thanks!
It's not a Rubicon, but it did have 4:10's. Yes, I did recalibrate my speedo. I'll check the RPM's this morning.
Old 06-23-2011, 04:51 AM
Former Member
dwhitt74's Avatar
Originally Posted by TheDirtman
According to the chart a 35" tire which is most likely 33.5"-34" in an actual mounted height should turn around 2350 rpm at 70 mph with 4.88 gears on an auto.
But isn't that using the 3rd gear ratio of 1:1? with overdrive, the rpm's will be less right? I'm just diving into the re-gearing swamp of opinions and posts and trying to get the facts. Thanks!
Old 06-23-2011, 04:52 AM
tslewisz's Avatar
You searched and couldn't find a gearing thread?
Quick Reply: 4.88 gears versus 5.13 for 4 door auto jk
