4.75 Backspacing on a 37" tires
Old 08-03-2012, 10:46 AM
Skumbag's Avatar
Default 4.75 Backspacing on a 37" tires
How bad am I going to rub? 37" Toyo M/Ts & 17" 4.75 bs Procomp 7069?
I was hell bent on the wheels. Do I have any options to rub less? Help me out guys.
Old 08-03-2012, 11:07 AM
kaptkrappy's Avatar
I think we need more info.
What size tire is it = width? What lift do you have?
Wheel spacers fix everything. (almost)
Old 08-03-2012, 11:12 AM
Skumbag's Avatar
They're going to be mounted tomorrow on my Stock JKUR suspension. I'm awaiting a RK 2.5 kit. Tires are 37x13.50R17. What is the most amound of backspacing you can run without hitting wheel on caliper?
Old 08-03-2012, 01:18 PM
hagausaf's Avatar
First off your mounting these tires with zero lift and stock flares?
Secondly, yes they will rub like a mofo. I currently have 37x12.5 tires, 3.5" lift and 4.75" BS wheels and they rubbed bad on the lower control arms and sway bar. Fixed all this with Spydertrax 1.5" wheel spacers. I'm now at 3.25" BS
Old 08-03-2012, 01:22 PM
EzK
EzK's Avatar
First I say stick them in the shed until your lift is on.
Second, you'll probably need some big bump stops with factory flares and 37s.
Old 08-03-2012, 01:37 PM
medbender's Avatar
youll most likely need at least a 1.5'' wheel spacer and trim the pinch seem. i run the same tire size (toyo) be sure to check for rubbing on the upper spring perch when the tire is stuffed durring articulation
Old 08-03-2012, 02:03 PM
mr.wolf's Avatar
Ur going to rub lol
I have 37" toyos on 17s with 4.75 bs and I'm rubbing on LCA's
I'm waiting on my new wheels witch are 4" BS to fix the problem.
Old 08-03-2012, 02:37 PM
11REDJK's Avatar
Oh yeah, you gonna rub on LCA. Possibly the top of spring when flexing.
Old 08-03-2012, 02:44 PM
hagausaf's Avatar
Originally Posted by mr.wolf
Ur going to rub lol
why not just get spacers? cheaper and can use your current wheels.
Old 08-03-2012, 03:07 PM
mr.wolf's Avatar
True. My wheels came with it as I got it used. I just want something different, kinda want to make it my own..
Quick Reply: 4.75 Backspacing on a 37" tires
