4.56 or 4.88 Gears?
Unless the Willys is decked out with armor or on 37's, I wouldn't want the 4.88's for the highway and 70mph.
Great information here! I am new so this helps a bunch.
Looking at a buying a used 2016 Willys with 6 speed manual and 4.88s. I will be using this for a daily driver for in city and highway driving. About 50/50. I do live on a mountain so I have to climb that coming home every time I would be driving it.
On the chart above, what does full time OD use mean please?
I do have some concerns here about top end on the highway and engine revs at 70mph. Any thoughts here would be much appreciated. Thanks!
Here is something to consider when your regular commute involves highway AND mountains. You're either going to be revving a bit higher on a flat highway on the top end, or revving higher due to having to downshift to lower gear in the mountains. I've not owned a 6-sp wrangler, but I will tell you that revving 2700-2800 rpm on the interstate isn't bad and is about perfect for me. It's a fine line of getting up to 3k+ for an extended cruise is where the engine noise gets a bit aggravating to me.....you know, long road trips with cruise control and engine at 3k. Either way when you get out of that little green zone on the tac (above 2500 rpm), you're not gonna see the "eco" light come on much.
OD is overdrive, not relevant to the 6-spd. Guessing whoever made those charts was lazy and just duplicated that part from the auto? idk I don't look at the manual chart much and have to say I never noticed that.
Maybe a dumb question, but ideally for flat highway driving, is there a RPM that the 3.6L operates with the best fuel economy?
I only ask because I'm gonna be upgrading my 2017 JKU with a 3.21 to 34" and likely eventually 35" tires. It's an automatic and primary highway and city driving, moderate hills as we are at the foothills of the Adirondacks. I know a re-gear is in my future, I was also unsure about 4.56 or 4.88. I want to do it once and be done. Looking for the best possible fuel economy.
You're driving a jeep. All I could really say is ANYTHING you do after you start modding is going to make it less fuel-efficient. I'd opt for a higher revving engine over lower revving and more stress on the transmission. I used to be more concerned about RPMs, but my jeep, solo, gets better fuel economy with screaming RPMs at a lower gear through mountain climbs than the jeep gets towing my trailer on the interstate on flatter land in 5th gear and lower RPMs. There is a point though that the engine noise gets a bit loud, and for me that is cruising around 3k rpm regularly. That is subjective though.
Not being a smartA.. on the tach is a green area.. this is the optimum RPM range for economy.. now looking at the chart on this link:
https://www.google.com/search?client...aboqHtQammUM2M
you could surmise what would put you in the optimum RPM range. FYI.. most 35" are not full 35s most are slightly less. Good Luck with the re-Gear.
Another gear related question. It's pretty clear that tire size is an important factor. How much of an impact would the weight of the tires or weight of the jeep in general be in regards to gear selection?
Weight of tire/wheel combo is going to have a big impact on performance, but it's not the difference between choosing an additional step up/down the gearset ladder IMO.
