4 50 inch led light bar roof rack mount?
I'm trying to find a roof rack that I could mount four 50 inch led light bars facing each direction on. I already have two of the four. I think it would be sick to have them facing each direction. Anybody know a roof rack mount I could do this with? Or if not! A custom place willing to try! Haha thanks!
Former Member
The Body Armor Rack has four light tabs in the front and two in the rear.
The mounts for those tabs are a bit close together to run a Rigid or most import light bars. Vision-X light bars have a sliding mount system that would work directly on the tabs. The front tabs are 33.5" front mount to mount and the rear are 34.5". Alternatively, to use 50" Rigid or similar import bars, you can use 2" tube mount light adapters. Warn, KC and several other companies offer them.
on my phone, tuff to get a link. it's Body Armor part #JK-6124. pervious post is correct about the tabs. but I didn't use the tabs to mount my existing light bar. I just drilled new holes and bolted the bracket to the rack. same can be done on each side.
EDIT and here's a really bad pic I just took
Mother of God, I have 1 50" and it's to bright for the trails and wouldn't even think about turning it on if someone is in front. I would like to see it just for shits and giggles lol
