4.10 + 35's = better MPG?
Old 12-23-2009 | 11:38 AM
LAHAL's Avatar
Default 4.10 + 35's = better MPG?
Hi,
Just wondering if you go with 35's and keep the Rubi 4.10. Will you get better MPG? I know its a dog for the automatics, and that 6th gears is pointless with the manual. But if you had the speedo reprogrammed, would you get better MPG compared to the 32's with 4.10s?
Thanks
LAHAL
Old 12-23-2009 | 11:43 AM
PG-JKU's Avatar
My guess is that it would be worse, unless you were calculating running mpg on a dyno with no wind resistance factored in. Street? Highway speeds? So many factors.
Old 12-23-2009 | 11:44 AM
Locklain's Avatar
I have the 3.73's in my Jeep with a manual and 35" tires and 6th gear is fully functional. I may have to downshift when I reach a hill but everything else seems to work fine.
On a side note, the closer you get back to your stock gear ratio with the larger tires the more gas mileage you are going to get. I believe it is called the "drive by wire" system that will automatically lessen the fuel used when at higher RPMs kind of like that fancy displacement on demand thing in the larger motors.
Old 12-23-2009 | 11:56 AM
GoodysGotaCuda's Avatar
Who said 6th was useless? Mine does pretty well in 6th, with a tuner (that i demo'd) it was pretty
Old 12-23-2009 | 12:03 PM
nangulator's Avatar
I only get 13 mpg around town with a auto, 35s and 4.10s, I cant wait to put my 5.13s in.
Old 12-23-2009 | 12:36 PM
ifshinxs's Avatar
Originally Posted by LAHAL
Hi,
Thanks
LAHAL
In theory you would get better mileage due to turning less RPM's. In reality you will lose MPG...Even running 33's I noticed a loss in MPG...
Rotational mass, added friction, poor gearing and not enough HP to push it, all add up to a loss.
If your going with 35's. The 5:38's are the way to go..You'll gain some MPG back. More than that your 3.8 will operate in its powerband.
Old 12-23-2009 | 01:01 PM
I still average about 17mpg mixed driving with my 35s and 4.10. I have no desire for "speed" on my normal drive. I have done some extended trips where I held 80-85mph in 6th and rolled right along. Didn't track mileage on those however. I would not be happy with 6th gear highway rpms with anything lower than 4.88. No need to run higher cruise rpm with so many gears to be able to use. If i need more pull i shift, just using the 6spd to my advantage..
Old 12-23-2009 | 01:45 PM
westchester's Avatar
Must be your snorkel, we've got same specs and similar heavy shit added to JK, I get 11.5 around town, gets up to 13.5 on highway. Someone posted that the JK computer over estimates the milage, so we're probably in 10-12 area - I'd hate it if it weren't a Jeep - Love it...
Old 12-23-2009 | 02:17 PM
jeepmedic's Avatar
Great..my 35's are on they way and I have 4.10's.
Guess its back to gallons per mile
Old 12-23-2009 | 02:19 PM
Originally Posted by planman
The main difference is that you live in Vegas at a much lower elevation that me or the OP.
You lose a fair amount of horsepower for each additional 1000 feet elevation above sea level.
If you drove your JK more frequently at elevations over 5k feet above sea level, in the mountains, you would have the same experience as us--stock gears and 35s are quite poor, and gas mileage improves with lower gears.
At our elevation, even with a programmer (Hypertech or Superchips), 6th gear can only be used down hill with no headwind with 35s and stock gears.
Understood, we're only about 2500ft here. We do have a few grades and such. Not like actually being in the mountains all the time.
