39 inch Krawlers
#21
Finally had the chance this weekend to mount one of the 39 Krawlers - this one for the spare. My best eyeball/tape measure measurements on the spare (with no load) is 38.5 by 12.5, so pretty close to the described size. I'm running a 17x8.5 beadlock rim and they mounted up nicely with no issues. I used dynabeads for balancing.
#23
A couple of things.
I didn't know the 39" Krawler came in anything other than the red compound. Are yours DOT rated? I didn't think they were.
I run the blue compound 37's on my TJ.
Also, I thought the 39" krawlers were a 13.50 wide tire? Are they only a 12.50?
Krawlers run pretty close to "true to size", bu the Km/2's are short. This should be a good step up between those tires.
I don't know what the life of those tires are, but blue krawlers are about 20K miles and red are about 9K. Hopefully yours last. Did you buy them used?
When I bought my 38" MT/R's (which I run on my JKU), I considered the Krawlers.
#24
the softer compound isn't a facor to me right now. i wish they were available to the common consumer though then maybe id buy a set. I am putting these on a set of different rims so they only go on for crawling. I am in process of installing a set of 38's on my stock rims for running around on!!
#25
I have been running the 39s from april 10 till now. The Unlimited is a daily driver and pretty core trail rig. I would advise you to balance them with stick on weights. I have never had a good outcome with ceramic beads. this tire has a deeper lug than the KMs and in the wash have matched my 38sKms to the mile. the side wall protects the rim much nicer also. This tire, Blue Label ,takes a four hour drive, 85 MH, Weekend and Out, Fall And Winter. The Krawler is a far better tire than tha KM2. I would prefer the KM2 for a daily pavement snow driver. But you cant have the best of both worlds.
JP
JP
#27
I just bought a jeep with the blue labels on. Will I really only get 20k out of these? I'm considering getting a set of mud grapplers anyways but i end up driving 200-600 miles round trip to get to any decent wheeling so I don't want to ruin them just getting there.
