38s or 40s? and what size rims
#23
Here is what it looked like with the JKS track bar, and the axle wasn't even against the 4" bumpstop yet. The differential cover was clearanced, and we changed to a Teraflex trackbar, and gained more up travel than in this picture. But you would still be hard pressed to use shorter bumpstops, without having other interference problems before the fender flares.
#24
Something else to consider is power. I am running 38s on 1 ton axle. I can easily go bigger in with my current set up, but no matter my gearing, highway speed is the limiting factor.
So for now, I am running 38s. And after my super charge dies, will go to an ls and 40s
#25
Yah, I didn't spend a lot of time researching a ram assist. I went to PSC's web page and looked at one of their better systems, and it was $2200. I also guessed a little low on flat fenders for $360. After more research, most of the flat fenders that include inner fender liners, which I would want, at least in front, are about $700. So, to do it right, ... the difference for me becomes:
37s = $800
40s = $5700
And my wife just spent $6000 on new carpet for 1/3 of the house. Guess you know why I went with 37s.
I would be interested in hearing more real world opinions on how 40" tires can affect hillclimbing ability on a standard wheelbase 2 door JK. If anyone can report on that I'd like to hear it.
37s = $800
40s = $5700
#27
#29
Coming from someone who has a 2013 two door stretched JK.... What in the heck are you thinking about 40's for?
I've seen 40's on a two door. When you do find yourself with enough lift to stop rubbing on a trail... goodluck climbing anything. You're going to have a big chance of tipping over compared to fours doors. I've almost flipped my jeep with 33" tires back in the day because of the short wheel base alone going over an obstacle when my buddy with 35's and a four door went over before me using the same tract and had no issues. I run 37's with a 4" Lift on my two door and had to stretch the rear axle and trim the pinch weld seam(Not sure what the one person was talking about Jeep trimming them in production for 2013+ JK's). Also installed a Drag Link Flip Kit, Reid Knuckles, TEN Axle Shafts front + rear, Tom Woods front + rear Driveshafts, 5.13 Gears, Upper and Lower C Gussets, Inner Axle Sleeves, 1 Ton Tie Rod, TF Big Brake Kit, and over course HD Ball Joints. All those things were installed just to feel comfortable wheeling my Jeep and not having to feel like I have to baby it. I'm still planning on picking up a Sector Shaft Brace and Hydro Assist soon aswell.
Just my .02
Just my .02
#30
Coming from someone who has a 2013 two door stretched JK.... What in the heck are you thinking about 40's for? I've seen 40's on a two door. When you do find yourself with enough lift to stop rubbing on a trail... goodluck climbing anything. You're going to have a big chance of tipping over compared to fours doors. I've almost flipped my jeep with 33" tires back in the day because of the short wheel base alone going over an obstacle when my buddy with 35's and a four door went over before me using the same tract and had no issues. I run 37's with a 4" Lift on my two door and had to stretch the rear axle and trim the pinch weld seam(Not sure what the one person was talking about Jeep trimming them in production for 2013+ JK's). Also installed a Drag Link Flip Kit, Reid Knuckles, TEN Axle Shafts front + rear, Tom Woods front + rear Driveshafts, 5.13 Gears, Upper and Lower C Gussets, Inner Axle Sleeves, 1 Ton Tie Rod, TF Big Brake Kit, and over course HD Ball Joints. All those things were installed just to feel comfortable wheeling my Jeep and not having to feel like I have to baby it. I'm still planning on picking up a Sector Shaft Brace and Hydro Assist soon aswell. Just my .02
Define "stretch"? Those who do run 40s generally have a total of 10"+ of combined front/rear stretch.
You can run 37s with 2.5" of lift all day long. I did and with 14" and 12" of travel.
Being unstable is a suspension issue. Happens when you get a tall off-the-shelf lift (like 4.5" for a two door on 37s). That combined with large tires and not cutting metal for uptravel results in instability.
