37X13.50's Do you need wheel spacers?
I have 4.5 inches of backspacing. I am looking to run the Toyo 37X13.50 MT's.
Will those tires (a true 13.50) clear with 4.5 inches of back spacing or do I need to run wheel spacers with them?
Anybody running the 13.50 toyos on 4.5 bs.
I believe the stock Rubi wheels are 6.5 inches of backspacing, so you would have somewhere around 6.25 inches of backspacing when accounting for the spacers. I am surprised that you are not having issues with rubbing when fully articulated on the front axle.
they'll work but you will have rubbing at a full turn. however, if you run wheel spacers like me, they won't tuck up under the fenders any more and unless you have sufficient lift, replace or trim them, you will rub there at a flex.
As long as they clear the rear upper control arms I think I would be able to drive it and see what rubs up front. Then I hope to make a decision on the spacers.
I have my Jeep pretty centered with the track bars, so I am hoping to avoid the rubbing if possible.
Those TOYO 13.50's are some wide tires and they run true. Hopefully it all works out.
