37s - Good aggressive AT or Mild MT
![](https://www.jk-forum.com/forums/images/ranks/veteran_navy.png)
Have you seen the new General Grabber X3? They will be released in the fall. They are on General Tire's website. I have had Grabber AT2s on my ZJ and WJ and they were excellent tires. I'll need to replace my Nitto Trail Grapplers in about 10K mikes and will be giving the X3s a look.
The little I have heard about these tires is that they are designed for 3/4 ton plus pickups that haul or pull heavy loads. I think I saw a FB or YouTube video with a Nitto rep specifically saying they weren't the best Jeep application. Has anyone else heard this or have thoughts otherwise? I like the look of these tired as well.
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
Alost all of the 37" tires available are designed for 3/4 and 1 ton trucks. Its hard to find a good 37" tire designed for a jeep as they are not a good fit for a daily driver jeep.
I'm curious as too why you would not consider the STT Pro equivalent or similar to the Duratrac in performance? I would call both an extreme all terrain, but the STT Pro with a more aggressive sidewall tread for when air down or while in ruts. From my perspective, I would place them on pretty even ground with each other.
I've run 35" C rated MTR/K's at 28psi (chalk tested) and 37" E rated STT Pro's and Toyo MT's at 26psi (chalk tested). I'll be damned if I could tell any difference in ride quality outside of the MTR/K's wobbling because they wouldn't balance and one was out of round.
The Nitto Ridge Grappler will be no more different than the other 37's available, but they are offering them in an F load rating for heavy 1 tons that will be towing. The 37x12.5017 will be offered in a reasonable D load rating, which will be fine for the JK.
