37" tires on 17" what PSI do I run
My Jeep JK weights in at 5300lbs on a scale. I have 37" BFG A/T 12.50 17" tires. I'm running them on a 8.5" wheel. What tire pressure do I run on the street because at 25lbs I still am getting some crown on the tread pattern. I run 27lbs in front and 23 lbs in the rear. what should I run when off roading. DON'T want to blow the bead?
