37" tire necessities
#61
Great thread with some great info. I got the green light to go with 37s today from the wifey
I'm going to go the economical route and beef up my D30 and D44 rear little by little. Definitely going to do some sleeves, gussets, and maybe a re gear for starters. Maybe add some custom drive shafts down the road. I'm running a 2.5 lift so looks like some flat fenders are in my near future too.
I don't wheel super hard since it's my DD and I'm not trying to break stuff unnecessarily!
#62
I was wanting to just regear and add lockers, when I added that up it got me started looking at the Dynatrac unlimited at Northridge's d44 with ARB and your choice of gearing
Going the normal route, I would look at upgrading axles first
I probably missed it but are you running a two door or four?
They say with a two door that your front driveshaft is more sensitive to lift height...
That's why I put in a 3" lift
Plus with 37's you want to watch your center of gravity
Matthew
#64
#65
I wasted money beefing up my Dana 30 and ended up blowing the gears not wheeling hard at all (5.13 gears).... also my DD 09 jku X auto. I now have the PR44 up front if I were to do it all over again I would have went straight to getting the PR44 even tho it's more $$$$ I feel I wasted it in the first place.... Now I wheel harder and with no worries.... Just food for thought.
#67
make sure you have the clearance to run them, not sure if a 3.5 in lift would let them fit comfortably i run 37's on my 10' jku but i also have a 6in lift and its still a little snug. might look into wheel spacers as well.
#68
That's the route I almost went...
Matthew
Matthew
#69
I have a 4-door. The more I look at the Dynatrac the more I think I should just save the coin and do it right the first time. It's just hard to drop that much $ all at once! But you're right, I'd hate to spend $2k, not including regear & locker install, to reinforce a D30 with sleeves, gussets, truss, and RCV axles just to start blowing gears. Might as well go with the Dynatrac and be able to enjoy wheeling without fear of breakage!
#70
Yeah my plan is to sleeve and gusset my D44 and regear to probably 5:13s even though I'm kinda thinking 5:38s. Hopefully that will be good enough for the wheelin that I plan on doing up here.
