37 on stock spare tire carrier and other ?s
#22
I guess my stock parts are just stronger than everyone else's stock parts then. Because I can assure you I do not baby my jeep, and I have had absolutely no issues yet. Either that or you all are driving like complete fools offroad, pretending you have one tons when you don't. Or simply don't understand the limits of stock axles. I'm not sure what it is, but there is some factor that is causing people to break so easily on just a 37, when I haven't had any issues yet. I have gotten my front end airborne multiple times and came down hard not to mention riding down wallops at 30mph. No issues. Idk what to tell ya. There is something that is different though. And I can promise it isn't the fact that I "don't wheel hard" or something ignorant
#23
People who re-gear are far more likely for failure as there is less contact between the ring and pinion. Can't say I've seen 3.73s go, but 4.88-5.38 is most of what I see.
Lastly, 37s far exceed the rated capacity of the D30. In fact, they exceed the capacity of a D44. That doesn't mean it will break, but most assume it is a likely outcome.
I've been around these boards for years. And Dirtman will tell you the same thing. I can't count the number of people who have said they run xyz on a D30 no issues, only to blow gears at some later point. Some of them used to pound it home on the forums. The irony was great.
Most anyone I wheel with now is running 40s and at a min a D60. I can't recall a time we went out and someone didn't break an axle shaft or blow gears. What you may think is challenging terrain, is a service road to a trail for someone else. The probability of a heavy JK with 37s and a D30 following us for a weekend in TN or KY and not blowing the front, is very low. Does that mean we have a heavy foot? No. You have to push your rig or you're not going to make it. If you want to winch all day, we're not the group for you.
Everyone's use case is different. Aside from all that is the simple fact that 37s significantly exceed the capacity of a D30 and there isn't much to argue there.
#26
It was straight on. U-joints are very strong when the wheels are pointed forward. I've seen plenty of 35 spline RCVs break on a D44. I'm always humored by the conversation of where the "fuse" is. The only real fuse that has control is the driver.
#27
I'll say I use to say that the Dana 30 wasn't too bad. That still holds some truth as I bought the Yukon lifetime warranty so it is what it is. I fix the shit I break unlike a lot of people. That would make it very very silly to run a 30.
Invest is right. It's easy to say "you wheel too hard" or "you are too hard on the skinny pedal". Lol. I've been to a lot of Offroad parks and wheeled with a lot of different groups. There's a huge difference between what I see a lot of people do, and what my friends and I do. The things people get out and spot each other for we roll through at 4 am at night and never stop... there's also a HUGE difference between your Texas wheeling and what we run around here. While you guys are out flexing on sand rocks we're climbing hills from the bottom of a creek where it's a mix of sick rock, mud, tight trails, and waterfall climbs... it's a big difference.
