37" Setup
Old 05-30-2011, 02:09 PM
jeepjackal's Avatar
Originally Posted by Mark
Is it better to have a Dana 44 over a 30? yes. Is it nesissary? no. Are there lots of people on 37's with a Dana 30? Sure is- theres even a thread on here post "who has 37's on a 30".
It all comes down to how hard you drive it. If you never take it off road, you might never need anythign more than a 30. If you drive it hard over rocks every weekend, you'd even brake a Dana 60 sooner or later.
Its a Wrangler. Rule 1- Build it how you want it, and start saving for when something breaks.
a d30 is the same thickness as a d44, if you gussett and strenghten the d30, it will be just as strong as spending the crazy amount of money for a d44.
Old 05-30-2011, 08:30 PM
Jeep Hound's Avatar
Originally Posted by planman
First try higher quality fluid and an in line cooler.
Sent from my DROIDX using Tapatalk
That's a great idea. I didnt know they made an inline power steering cooler? Any manufacture you would recommend?
Old 05-30-2011, 09:10 PM
Jeep Hound's Avatar
Looks like this is my next upgrade. Do you have any photos of where you mounted your cooler?
Old 05-31-2011, 09:21 AM
Jeep Hound's Avatar
Same place as this guy:
Thank you I'm gonna do this set up
Old 05-31-2011, 11:24 AM
Sin City JK's Avatar
What's the same thickness on the 30 and 44? The housing/tubes? just curious.
Old 05-31-2011, 10:40 PM
orfanidisnikolaos's Avatar
So would you suggest to run 37s in a D30 with gussets and sleeves? Would it last, considering the fact that I do medium wheeling to my JK?
Old 06-01-2011, 04:01 AM
jeepjackal's Avatar
i havent found a front axle for under 5 grand, getting a d44 can be costly.
Old 06-01-2011, 06:04 AM
jctnt1's Avatar
Look at the Classifieds section on this forum. They routinely go for $2k-$3k depending on mileage and modifications.
listen to planman, "Rubi" D44's with factory lockers go for around 2k. you can even find some already built up with gussets and sleeves for 3k. Ring and pinion size does matter. trash the d30 and don't look back.
Quick Reply: 37" Setup
