35's on stock spare tire carrie?
Former Vendor
I ran a 35 off the back of mine for a short time, tailgate began to de-laminate and make wretched noises when hitting the smallest of bumps in the road. Definitely worth the investment of an aftermarket carrier... I personally run the TeraFlex hinge w/ adjustable mount w/ 37" Mud Grappler, solid as a rock... (92lbs of rubber)
![Rock](https://www.jk-forum.com/forums/images/smilies/rock.gif)
![](https://staticssl.ibsrv.net/autocomm/Content/JK-Forum/jkamicon.png)
I can tell you that my toyo 35x12.5/17 did not fit with stock bumper. My 285/75-17 which are 34's fit but my 35'sdid not. I already had the TF hinge and had to add the TF carrier it is solid as a rock.
After seeing a buddies 15' sahara end up with a nice visible crease on the tailgate from a 35" Kenda Kleaver mounted on a 17" stock rim after barely a month of carrying it, I wouldn't recommend it. Although he wheeled with it quite a bit in that month.
![Question](https://www.jk-forum.com/forums/images/icons/icon5.gif)
Will the stock tire mount still work with the Teraflex hinge, or do you have to also buy their adjustable tire mount?
That hinge looks awesome - just the hinge is $479, not horrible, But if you have to buy their tire carrier too now it's up to like 700 to make it all work... ?
Edit- found the install info on their website, looks like the stock tire mount will work with the hinge. So my plan is to just get the hinge and still use my stock mount w/ the extension I already have. Any advice, is this a bad idea? (I gotta do something, just noticed today that one of the pinch welds is starting to let go.)
Thanks!
Thanks!
Thanks!
Thanks!
You don't have to, but the adjustable carrier allows you to suck the spare up tight against the tailgate, and raise it up out of the way. I know it's really not that much cheaper than a swing away carrier, but it does add some beef to the gate without all the weight of a full carrier.
mine rattles have the 35 on there with quite a few wheeling trips. no welds are broke yet, it does rattle a bit though because the factory rubber bumps don't mesh up with the tire. it barely fits as well, can't even stick my finger between the factory rear bumper and tire. 35x12.50r17 fierce attitude mt
Mine rattled slightly after putting a 35" KO2 on there. I had run a 33" Nitto back there for 4 years with no problem. A dude rear ended me and smashed the stock carrier. The collision place said they didn't have to replace it with the OEM carrier. I got the (cheap, but better) Smittybilt oversized carrier. It's supposed to be able to hold 190 lbs. Still some slight rattle, as it's still on the stock hinges. About 2 weeks ago, I took the covers off the hinges, cleaned them, tightened them, and lubricated them. So far, it's silent. I've never had any welds pop. I think before I spent what Terra Flex wants for their carrier, I'd get a tramp stamp and throw the spare in the back for wheeling trips.
I wouldn't trust it for anything over a stock tire size. I recently upgraded mine to a JCR Shield tire carrier setup for my JCR bumper and I couldn't believe how flimsy the tire carrier and mounting substructure within the tailgate is. The TeraFlex mount is a very solid unit and it is a worthwhile investment. Stick the spare in the tailgate area or in the garage until you need it for a trip and spare your tailgate the agony.
RockZJ
RockZJ
