35's on Stock Rubicon Wheels
Old 03-03-2008 | 10:02 AM
AZJeeper's Avatar
Originally Posted by jkkat
Super Swamper SSR's come in 35x 10.50 x17
Actually, thanks for making my point. If you go to the Super Swamper page, look at the "Rim" column. The widest tire they have that fits on a 7.5" rim is only 9" wide. I have no doubt you can squeeze a bigger tire on a too-small rim, but how does it air down? Does it void any warranties? How is the load rating affected? Any wear issues since the tire will tend to crown? Will the tire roll off the rim easier?
There may be some advantages to running a narrow rim. Less likely the tire will pop a bead?
I heard of a rule-of-thumb that the tire width should not exceed 4" of the wheel width. Given that unconfirmed rumor, 11.5" should be OK.
These are the issues I've been wrestling with since I would also like to put a bigger tire on the stock rims.
The table shows the rim width for the 35x10.50x17 SSR is 8.5-11.0 inches.
http://www.intercotire.com/site34.php
Old 03-03-2008 | 10:30 AM
Duke's Avatar
My JK with BFG M/T 37x12.5x17's on a stock Rubi wheels.
And yes the manufacture does not reccomend these tires for these wheels, but.............
BFG also doesn't recommend running my tires with 7 PSI offroad, which the narrow rim helps maintain much better than a wider rim.
Jeep recommends against modifications to factory suspension systems.
You want a picture of my old truck with w/ 44x18.5x16.5 Swampers on 16.5x9.75 Welds?
Old 03-03-2008 | 09:25 PM
strike2dr's Avatar
I am running 35X12.50 on my stock 17's with no issue. I will actually run 10 lbs of air while i am offroad without one issue. People have been doing it for years without a problem. I run 26 lbs all around for daily driving leaves a great foot print and rides even better! JUST DO IT
Old 03-06-2008 | 08:18 PM
ebc-tmc's Avatar
what are people doing about the spare tire-even with a spacer, a 35 will not fit on the stock bummpe...from what i can tell.
Old 03-06-2008 | 08:26 PM
VBS4's Avatar
A 35 will mount on the stock bumper. The only thing you have to worry about is the offset of the rim.
With my procomp rims, my 35 mounts fine on the rear. With the stock tire, you will have to put a spacer (same spacer you'll use on all 4 tires) on the stock tire carrier.
There are a bunch of threads were people have done this. I would have gone this way if I hadn't found a good deal on my procomps.
Good luck
edit......There's also a company that made a plate that mounts like the spacer but raised the tire up an inch or so.
Old 03-07-2008 | 05:12 PM
miket@teterop.com's Avatar
Default Stock Wheels W 35s
Worked Great For Me,no Problems At All!!! Spare On Other Hand. Anyone Know That Web Site For Adapter That Moves Tire Up An Inch???
Old 03-07-2008 | 05:33 PM
VBS4's Avatar
look at this thread. Last post on the page
https://www.jk-forum.com/forums/modified-jk-tech-2/can-i-fit-tire-my-rear-stock-tire-carrier-1002/
Old 03-08-2008 | 09:57 AM
HULKGREEN's Avatar
I have 33x12.50x17 also and have had no issues !!
http://my.project-jk.com/data/508/me...3_4584_011.jpg
Old 03-09-2008 | 08:35 PM
swampdonkey's Avatar
I have the 1.5 spacer on my spare. I also have a 1" body lift, and without the body lift, I'm not sure the 35" spare would clearance the stock bumper.
Old 03-10-2008 | 01:48 AM
ToTheWall's Avatar
My 35 clears everything just fine on the tailgate. NOT stock wheels though. ProComp 6089s. If the backspacing was .25" less it would rub the stock rear bumper. I cannot see the stock wheel fitting in any way shape or form without a spacer as it would be sucked in there too close.
As an asdide... I do like how the engineers thought ahead and set the third brakelight high enough that it clears a 35" tire.
