35s on stock auto gears?
Old 10-11-2012 | 07:17 PM
Florida904's Avatar
Thanks for all the replys! 35s would be the largest i am wanting to run since i drive this many miles a day how much power will i lose keeping the same gears for a few months after switching from the toyos which sit kinda a 34 that are heavy compared to the duratracs that will be 35s but aren't the duratracs lighter than the toyo's?
Old 10-11-2012 | 08:40 PM
Ryan0260's Avatar
It will be a dog. You might get by if you get a tuner and keep the overdrive off, but I would re-gear it
Old 10-11-2012 | 08:54 PM
TheTerminator's Avatar
Originally Posted by Florida904
Im running toyo 33s on 17 addicts currently and am looking at going to 35 duratracs can i get by not re gearing? im currently getting about 16 mpg
I see a lot of people come and ask this question. My advice is get the tires first, then decide for yourself if you need to regear or not. Only you can answer this question, because it's a very subjective choice. When I went from stock 255 tire to 35 Kevlars, I noticed only a slight degradation in performance. I actually thought braking is a lot more diminished compared to acceleration. But now I'm used to it, so I don't even think about it anymore. I already had a Superchips and calibrated my speedo. Yes, gears would help, but for what they cost I just don't feel they're worth it. You're basically paying $1600 to get 1st gear back, which is still quite usable, especially on pavement. Off road it could be lacking, but it's livable. And then there is always 4lo.
If you want to keep your 3.73 gears, make sure to ALWAYS turn off OD, city or highway. Some people think it's a dog, because they likely keep OD on. When you turn it off and reach highway speeds, you're effectively running 5.38 gears with OD on. Which means, there are 0 issues on highway with 3.73 gears. It's actually better than 5.13, because you have more power. In city it's very fine too. You can keep the shifter in 2nd gear to have lots of power around city, but 3rd also works fine if grades are fairly flat. After you try that, see where your RPM are, and where they'd be if you regear, you'll probably understand my point.
Also, since your current tires are already in between of stock 255 and 35's, and you'll be switching from mud to AT tires, which also weigh probably the same, I'm pretty sure you won't feel much difference, if any at all.
Old 10-11-2012 | 09:50 PM
courtsm3's Avatar
hows your mileage with OD off? what rpms are you up to at 100km/h? ughhhh guess i could try it myself tomorrow lol
whats up from Chilliwack!
Old 10-11-2012 | 10:16 PM
My mileage is surprisingly great on the highway. It is in 19's driving from just south of Seattle to Bellingham. I did this like 4-5 times and got consistent mileage in 19's, driving around 100 km/h with cruise control. This was with 87 fuel and 87 Superchips tune. Recently I switched to 91 tune and 91/92 fuel (depending on what's available), did the exact same drive and got 16's mpg. I still need to drive more to confirm this, but so far it seems like the 91 tune dropped my mileage considerably. From Vancouver to Squamish on 87 tune, I'm in 16's, but that's not really a highway... although you get the idea. It a lot depends on the road. I imagine from Vancouver to Chilliwack I'd get 19's. Stock driving to Squamish I could get 19's. Otherwise on a normal highway I'd be in 19-20's. In city I'm in 12's, but I was in 14's on stock 255 tires. My city mileage always sucked for some reason, can't figure out why I'm trying to use 3rd gear more in city now, as it seems to be better for mileage than 2nd gear. With 2nd gear I was consistently in 11's. Sorry, lots of numbers but these are my experiences.
Oh, and my RPM in 3rd gear (OD off) at 100 km/h is around 2250.
Quick Reply: 35s on stock auto gears?
