35's Question... Go figure
If you run them with no lift off roading, make sure someone is always behind you, to pickup your fenders once they fall off.
You should be fine on roads but the air dam will rub and you probably should remove it all together. I have rubi unlimited and I could not turn (full lock) or go reverse without it 35s rubbing on airdam.
