35's Question... Go figure
So the place I work next to is having a great tire sale and I need new tires. I wanna run 315/75/16 on my stock X wheels. I have no lift, but I'm not gonna go off roading until I get my lift. Can I run the spidertrax 1.5 spacers and 35's with no lift? For now...
I've seen other people squeeze them in but personally I don't think it would be good. Buy the tires and hold onto them till you get the funds for even a cheap 2.5" budget boost. then they will fit with spacers.
But I'm needing tires, about to take a trip and having so little tread these hydroplane really easy. Should I just do 33's even though its not what I want.
Put the 35s on and worst case is you hit a big bump and rub your flare a little. You said you plan lifting soon, so you should be fine. You wont be the first to do 35s no lift.
You can do a search 35s no lift and see other that have done this. Search it a few different ways. There are a bunch of post.
You can run them as long as you have 4.5 backspacing. I ran 35s with my flat style fender flares and it just rubbed the plastic splash guard inside the fender well. Little trimming and I didnt have a problem
