35's E-rated What PSI are you guys Running
Old 04-07-2013, 04:21 AM
KE4JR's Avatar
Default Advised by Toyo
See, everybody has a different answer and that's why I contacted Toyo. After the tech got all the info on my (2013 JK, sahara 4 door, auto tranny, 18 rims and 35" Toyo's) they came back with the answer, "we recomend 40psi cold"
Old 04-07-2013, 04:35 AM
GJeep's Avatar
The 'recommended' pressure is typically too high.
With around 30psi, most tires of this size feel good and have the tread sit flat - which is what makes them wear evenly.
You may try the chalk test.
Inflate to 30psi, use a chalk to mark a thick line across the tread, drive a little bit, and look at the chalk line.
If the chalk is gone at the center, the pressure is too high. Lower the pressure by 2 psi and check again. If the chalk is still gone at the center, reduce by 2 more psi and re-check.
If the chalk is gone at the sides, the pressure is too low. Increase the pressure by 2 psi and check again. Not enough? -- add 2psi and re-check.
When the chalk line wears off evenly, that's the pressure for even tire wear.
Tire pressure changes with temperature.
If you filled in cold air, then drove on a highway in hot weather for 2 hrs, there will be a few psi increase, and vice versa when the temperature drops compared to the temp' of the air which was used to inflate.
Old 04-07-2013, 04:54 AM
slider_68's Avatar
Been running the same tire as OP for over a year now at 30psi on the street, chalk tested, rotated every 5k, showing nice even wear patterns
Old 04-07-2013, 05:48 AM
Pete1971's Avatar
I agree with this & it does work
Old 04-07-2013, 07:37 AM
Ryan0260's Avatar
Way to high for our Jeeps...
Old 04-07-2013, 08:31 AM
JKBANDIT55's Avatar
I stay around 32psi on my 35s. Anything higher and my jeep feels bumpy and wonders everywhere. 40psi is Wayyy to high if you ask me.
Old 04-07-2013, 09:00 AM
Billbikes's Avatar
First I have 33s, but my tires(Trail Grapps) bounce like crazy with anything over 32 psi. I've found 29 psi to be perfect. So they may wear slightly faster, but I don't want to drive a springboard!
Old 04-07-2013, 10:34 AM
Grn Jeep's Avatar
Im running 32 psi in my BFG KM2's 35x12.5x17 D rated
Old 04-07-2013, 11:43 AM
jtphoto JK's Avatar
25psi in 35x12.50x17 PitBull Rockers. Rotated every 5000klm (3000 mi) tread depth checke every rotation = nice even tread wear.
Old 04-07-2013, 04:26 PM
MidwestRubi's Avatar
so i just got a set of 35-12.50-17 cooper STT's and i'm running them at 26 psi i havnt done the chalk test or anything but i can see that the tire isn't sitting flat, the side lugs aren't even making contact with the road , they're E rated tires and i have a 2 door rubicon, i wanna take more out of them to get the tire to sit flat , but at some point i'm thinking it will be too low for road use, does anyone else run this size on a 2 door and have any suggestions ?
Quick Reply: 35's E-rated What PSI are you guys Running
