35's or 37's for jk 2 door
Originally Posted by jerseyjkredneck
I like the look of the 37's but not sure if it's worth all the extra work and money needed to make it run right.
Some beaches don't allow tires over 37" and you will have to upgrade driveshafts depending on the size lift. You would Probably get 4-4.5" with MAYBE a BL?
Teraflex 3" or 4". 3" should net you about 4" of lift. If you plan on bumpers and a winch, go with a 4". OR, what I would do is a 2.5" teraflex lift, 1" BL, trimmed pinch seam, bump stops, and flat flares. No need for drive shafts on a manual with this set up
