35's, 3" lift and REAR ds
I'm waiting on delivery of a 6-spd manual 2012 JKU. Already have a Full Traction 3" Prem Plus lift, and a JE Reel front ds to avoid the exhaust crossover issues on the '12's.
While talking to the techs @ FT, they mentioned that I'd probably want to get a new rear ds eventually, as well. Since I was dropping 2K on the lift, and buying 35's, new wheels, etc, I decided to hold off on the rear ds.
Now I'm thinking that might be a mistake.
Of course, I have a tendency to overthink things.
What do y'all think? Will I be good for awhile without the rear ds, or should i just go ahead and get it, then install it along with everything else?
My Jeep's a dd, but I'll wheel it on weekends. I'll also wheel it in some fairly unpredictable situations for work (I've been to the Gulf Coast immediately after Katrina, the southeast after the recent tornadoes, etc). Also make a lot of long distance road trips.
Any advice would be much appreciated.
I installed my TeraFlex 3" last fall which netted me 4-5" lift as I still don't have heavy bumpers or other gear. I haven't had any issues with front or rear drivelines so far, and I wheel most weekends. I'll upgrade drive if I ever break them, but until then, stock is not just good, it's good enough!
Even a med-size lift leaves the front ds on the '12s at a fairly steep angle.
Yeah, the 2012 does make a big difference. I crawled under one on a test drive last month and that front pipe on the exhaust is just waiting to get smashed! I think the sales guy thought i was a bit nuts...
When I installed my lift (3" TF) my rear pinion angle was a little steep (I only had lower adjustable arms though). I bought upper adjustables and they fixed the problem. So, as long as you have adj uppers you will be fine.
