35's with 3" lift or 5"
Old 01-01-2011, 08:50 AM
  #21
HornetJK's Avatar
3" OME HD LT lift. 35" KM2's I"d say this is pretty good articulation.
ID:	114096   Click image for larger version
Old 01-01-2011, 08:55 AM
  #22
rinkishJK's Avatar
Here's my ome HD setup with LT shocks... flexes awesome!
sent by the rinkish with tapatalk power!
Old 01-01-2011, 08:58 AM
  #23
snopro269's Avatar
Nice pics guys. I want that lift!!!
Old 01-01-2011, 09:57 AM
  #24
josh_jacklyn's Avatar
Originally Posted by 07 JK "bullfrog"
I got an 07 2 door x. I got a 4" teraflex with 37s . Do the bigger lift, then buy bigger drive shafts
see that's what i did. bought the bigger lift, and will buy the drive shafts when my stock ones go out. saved me 1k out of the gate.
Old 01-01-2011, 10:07 AM
  #25
snopro269's Avatar
I was told that if I put the bigger lift in but keep short shocks on I won't have driveline issues. Then when I want more flex I just put longer shocks and driveshaft on.
Old 01-01-2011, 11:19 AM
  #26
Pluke the 2's Avatar
hmm somewhat true. the higher your lift, the more you offroad, the more you articulate the higher your chances are for ripping that front driveshaft.
here is my three inch ome hd coils with long travel shocks.
here is what happens when you do the above on an automatic transmission.
here is where the boot got ripped by my transmission pan.
Old 01-01-2011, 02:45 PM
  #27
snopro269's Avatar
Originally Posted by planman
When you run shocks that are too short or too long, you end up either topping out or bottoming out the shocks too frequently.
This can result in breaking shock mounts, bolts, or bar pins.
I would discourage running too short shocks off road. If you aren't going off road, then there is no reason not to run the correct length shocks.
Again, on a 2 dr, a 3" lift or taller requires rear coil correction and a trackbar that provides enough clearance for the rear passenger spring.
Yeah the tech from Northridge told me that info
Quick Reply: 35's with 3" lift or 5"
