35's with 3" lift or 5"
#24
#25
I was told that if I put the bigger lift in but keep short shocks on I won't have driveline issues. Then when I want more flex I just put longer shocks and driveshaft on.
#26
here is my three inch ome hd coils with long travel shocks.
here is what happens when you do the above on an automatic transmission.
here is where the boot got ripped by my transmission pan.
#27
Originally Posted by planman
When you run shocks that are too short or too long, you end up either topping out or bottoming out the shocks too frequently.
This can result in breaking shock mounts, bolts, or bar pins.
I would discourage running too short shocks off road. If you aren't going off road, then there is no reason not to run the correct length shocks.
Again, on a 2 dr, a 3" lift or taller requires rear coil correction and a trackbar that provides enough clearance for the rear passenger spring.
