35's with 3" lift or 5"
Old 12-31-2010, 09:23 AM
Jkmedic231's Avatar
If I do a 3" will that require new shafts?
Old 12-31-2010, 11:51 AM
MYBLUEJK's Avatar
Defiantly dont lift more than 2.5-3 with stock shafts. I have a 2.5 on my 2 door, stock flares, did some minor trimming but clears 34.5's easy. at full flex there are some minor rubbing points, but nothing serious, and will all go away if add a 1inch body lift or change flares.
Old 12-31-2010, 11:57 AM
josh_jacklyn's Avatar
how about 35's with a rk 3.5
ID:	113877   Click image for larger version
Old 12-31-2010, 12:11 PM
07 JK "bullfrog"'s Avatar
I got an 07 2 door x. I got a 4" teraflex with 37s . Do the bigger lift, then buy bigger drive shafts
Old 12-31-2010, 03:12 PM
boaz3119's Avatar
My front boot is thrashed and has been for a while, there are known instances of peoples lastin 50k mileswith boot torn. I personally would not base my lift on DS roll out till it starts clicking at ya then replace it
Old 12-31-2010, 04:14 PM
snopro269's Avatar
Originally Posted by FrankTheTank
In the best interest of your driveshafts and for a lower center of gravity, you can also keep it stock and use small spacers and flat fenders. This will give you the SAME articulation and flex as a 3" lift.
I know this because I just went from a complete 3" teraflex lift to the build I just mentioned above. It also got rid of my driveline vibration and the ride is a lot smoother too.
When you say spacers you mean wheel spacers
Old 12-31-2010, 04:17 PM
snopro269's Avatar
Originally Posted by planman
I run 40s on a 3.5" lift, 1" body lift, and flat flares on my 2 dr.
If I were building for 35s, I'd do no more than a 2.5" lift with either flat flares or a 1" body lift.
Done correctly on a 2 door, a 3.5"-4" lift results in about $1500-$2000 for the lift and another $1000 for driveshafts.
Whereas, a 2.5" lift done correctly runs about 1/2 the cost and does not require driveshafts.
The $1750-$2000 saved by going with a 2.5" lift can cover the cost of regearing, a Superchips Flashpaq programmer, and maybe even a winch or Bushwacker flat flares.
Sent from my DROIDX using Tapatalk
What 2.5 lift you suggest to go with
Old 12-31-2010, 06:38 PM
Merlin4979's Avatar
Teraflex, Rock Krawler, & Old Man Emu are all great brands that you really won't go wrong with for a 2.5" lift on any of them, and all will let you clear 35's easily.
Old 12-31-2010, 08:56 PM
vandegrift's Avatar
you can run a 35" with a TeraFlex 2.5" buget boost. I have a 3" full arm suspension from TeraFlex and it sits about 4". Leaves you room to bolt everything else on and still have room for the 35's.
Old 01-01-2011, 07:55 AM
snopro269's Avatar
Well I have bushwacker Flatties and an Automatic. I want a simple turnkey small lift without driveshaft lengthening. The guy at Northridge told me I could do the longtravel kit minus the long shocks and later on when I'm ready get a driveshaft and longer shocks
Quick Reply: 35's with 3" lift or 5"
