35's with 3" lift or 5"
Defiantly dont lift more than 2.5-3 with stock shafts. I have a 2.5 on my 2 door, stock flares, did some minor trimming but clears 34.5's easy. at full flex there are some minor rubbing points, but nothing serious, and will all go away if add a 1inch body lift or change flares.
My front boot is thrashed and has been for a while, there are known instances of peoples lastin 50k mileswith boot torn. I personally would not base my lift on DS roll out till it starts clicking at ya then replace it
Originally Posted by FrankTheTank
In the best interest of your driveshafts and for a lower center of gravity, you can also keep it stock and use small spacers and flat fenders. This will give you the SAME articulation and flex as a 3" lift.
I know this because I just went from a complete 3" teraflex lift to the build I just mentioned above. It also got rid of my driveline vibration and the ride is a lot smoother too.
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
Originally Posted by planman
I run 40s on a 3.5" lift, 1" body lift, and flat flares on my 2 dr.
If I were building for 35s, I'd do no more than a 2.5" lift with either flat flares or a 1" body lift.
Done correctly on a 2 door, a 3.5"-4" lift results in about $1500-$2000 for the lift and another $1000 for driveshafts.
Whereas, a 2.5" lift done correctly runs about 1/2 the cost and does not require driveshafts.
The $1750-$2000 saved by going with a 2.5" lift can cover the cost of regearing, a Superchips Flashpaq programmer, and maybe even a winch or Bushwacker flat flares.
Sent from my DROIDX using Tapatalk
you can run a 35" with a TeraFlex 2.5" buget boost. I have a 3" full arm suspension from TeraFlex and it sits about 4". Leaves you room to bolt everything else on and still have room for the 35's.
Well I have bushwacker Flatties and an Automatic. I want a simple turnkey small lift without driveshaft lengthening. The guy at Northridge told me I could do the longtravel kit minus the long shocks and later on when I'm ready get a driveshaft and longer shocks
