35's with 3.21 Gears
Old 01-26-2011, 08:37 AM
  #31
cosmec's Avatar
I'm in a similar boat, but my 6sp has 3.73 gears. Would throwing 35"s on be bearable with this setup?
Old 01-26-2011, 09:42 AM
  #32
Rafi's Avatar
yes very bearable... 6spd helps a lot, and its not bad at all...
i am in no rush to regear
Old 01-26-2011, 10:04 AM
  #33
RevyJKU08's Avatar
That is what I have heard for both the 3:21 and 3:73 gears that it's bearable with 35's & 6spd. I am going to risk it and jump to 35's this spring with my 3:73 gear and 6spd and hope I don't need to re-gear for a year or longer and that the mountain passes won't beat my JKU too badly running this setup.
Old 01-26-2011, 10:34 AM
  #34
Olean NY Jeeper's Avatar
I have been running 34s on stock 3.21 gears for almost a year. It is tolerable but I am regearing soon. I lost 6th completly and must be on highway to use 5th gear. Off road it is difficult to go slow enough. It is doable while you wait to save for gears. With 3.73, u may be ok for long term depending on ur driving habits and off roading.
Old 01-26-2011, 12:07 PM
  #35
hetkind's Avatar
I don't think 35" are doable on any STOCK axle but the Rubicons...I actually put smaller snow tires on my Sahara 245/75R17 at 30.5" over the 32" stock tires to lower the torque band for winter driving.
Howard
Old 01-26-2011, 03:07 PM
  #36
rexicon's Avatar
wow don't know how anyone gets over 20mpg in a JK even stock????
big tires = bad gas mileage no matter V8 or V6 or supercharger or gears....
Old 01-26-2011, 03:09 PM
  #37
rexicon's Avatar
Howard
I've seen 37's on Non-rubicons so I think 35's are doable. Heck I've got em.
Old 01-26-2011, 03:31 PM
  #38
Rusman161's Avatar
You have 37s on a non lifted? I though the minimum was 2.5 lift for 37s
Old 01-27-2011, 08:24 AM
  #39
crazyloggy's Avatar
Originally Posted by medic_23387
Just drove back from work 60miles and reset my MPG reader and in 6th gear at 65MPH I get 25 MPG easy sometimes 26. In the city I get around 19-21. I drive pretty easy but not like a granny. I try to shift around 2100-2200 to keep the RPM's down. Does anyone have an idea why I am getting such good MPG's. It is super flat on the interstate I drive on.
there is just no possible way you get that good as a average, fill your tank up hit the trip meter and let it get to a half a tank and fill it up again. then take your miles driven divided by gallons it took to fill it back up, then post up the MPG's. those MPG readings are highly inaccurate mine said 18.5 all the time but I'm lucky to get 14.5 MPG,s in reality.
Old 01-27-2011, 08:44 AM
  #40
Rafi's Avatar
Howard
35's are ok on d30's.
Quick Reply: 35's with 3.21 Gears
