35's on a 2 door without regearing?
You sure you don't have 3:55's? Seem's like 3:21's are a little low for an auto. I have an 11' with auto, 3:55's and 35's.(Duratrac's). It is pretty flat where I live and do not do much hwy driving, but it seems fine to me. I do try to run with O/D off under 50mph, because other wise it with run at about 1100 rpms at 45mph until o/d kicks in, then up to around 2000rpm's.
A regear is on my to do list(4:88's), but since it is ok now, it got pushed down.
Side note....I don't recall too bad of a hill in Pigeon Forge, I was just out there in September to do all of the tourist stuff there on my way back from KY on 75 across to 40.
Sent from my DROID4
Yes, it's fine- you're simply keeping it in gear. Now, I would certainly add a trans cooler since you'll be out of OD so often.
Sent from my DROID4
Even with 5:13's I do not use O.D on the highway unless over 70. The per '12 autos are geared so effin high that if the jeep had the power in stock form it is geared to go 207 mph lol
Sent from my DROID4
Sent from my DROID4
![YA Dance!](https://www.jk-forum.com/forums/images/smilies/wings.gif)
