35s with a 2" BB & 1" body lift?
Will that work ok?
I'd need to get a procal to reset the speedo. Will I need anything else? Should I get rims with 4.5" BS vs stock or will my stock rims be ok?
trying to figure out how much I'll have to spend.
I don't see why it wouldnt work. You'd have 3" of total lift which should be enough to clear the 35s fine. As for wheels, that depends on the width of the tires, not the height. If you're looking to run a 12.5" wide tire, you'll need spacers or wheels with less backspacing than stock.
Trimming the stock fenders would help too
