35 x 12.50 x 15 Mickey thompsons MTZ's won't balance.. WTF
I believe the amount of beads used refers to the tire size as the beads go to where it is needed. Here is the site I purchased my set from. I'm sure the site can provide you better information to your questions.
I found out about the beads by searching this site
ht tp://www.innovativebalancing.com/index.php
If they were trying to just standard spin balance them, I'm not at all surprised. Getting them roadforce balanced and my guess is they'll be OK and of course without 20ozs of weight.
I will post picks of the set up as soon as phone gets done trying to send then for those who would like to see what they helped me acheive.. thanks everybody here on the thread
Yeah I run them on my daily driver. There is a chart on the Dyna Beads site for the amount of beads to use for tire size. The off road beads are just larger so they do not get caught in the valve stem. I run ATX Slab Beadlocks so I mounted my tires/rims at home. I didn't bother taking my tires/rims anywhere for balancing.
I know exactly what is wrong with your other tires. My friend was working as a scab on a tire factory where all the workers had a strike and the factory brought in other temp workers. So no wonder you got shitty quality tires because my friend said those temps did a horrible job.
