35 w/ standard gearing
i got a 2010 unlimited sport auto and i got the 3.23 on front (30 dana) and 3.73 on the rear (44 dana) and i been wondering the samething i been doing some research and the dealer say's is fine since i been think about getting my lift with them and 35's with them.
That's where I am as well, lift kit gave me more lift than anticipated for 35s, the 3.73s weren't as bad as what was bantered around and I'm waiting until the meats wear out and a move to 37s before I'll spring for gears. I'll drive in 5th or 6th at 70mph with little to no difference in efficiency, and 5th being better for rolling hills. Will likely roll with 5.13s, just want to have the tires on for a week or so before I leap.
not that bad
i have a wrangker X 6speed with the 3.21 on 35, and around town isn't bad, on the highway i cant get it into 6th but it goes good in 5th. mpg r definitely going to drop. as far as wheelin goes 4high is useless, absolutely no power if your trying to go up or thru mud. i am going to save and put 4.88 in with a locker when my tree grows more leaves. good luck
Uh. Don't the gears gotta match front to back? Pretty sure they do.
Are you sure your running different ratios on the front than the back? I would think that would be causing some damage to something on the drivetrain.
