35 Toyo MT's on stock wheels chalk test
Old 03-16-2013, 08:47 AM
rickc309's Avatar
Default 35 Toyo MT's on stock wheels chalk test
24 psi in what it takes on my JKU to get the full footprint of the Toyo's with stock rubi wheels according to the chalk test. I was surprised it was that low but it is what it is. Started out at 30 psi and kept dropping it 2 psi per test until the pavement was making contact with the full surface of the tire. I'm sure with a wider wheel the psi could be increased. Just thought I'd share the results.
Old 03-16-2013, 08:50 AM
kjeeper10's Avatar
That's why I don't trust the chalk test.
What are you running, a 8" wheel?
Old 03-16-2013, 09:07 AM
Tonka_yellow's Avatar
What's the width of the tire and what wheels are you running..
Old 03-16-2013, 11:45 AM
rickc309's Avatar
Factory Rubi wheels are 7.5 inches wide. Why wouldn't you trust a chalk test. It's a straight up black and white test. If your using white chalk.. It's a true test to fit each vehicle. That same tire on an F-250 might require 45 psi due to the weight to produce the same results with a chalk test. It drives perfect and rides great. At 30 psi I was running on the center 6 inches of the tire. The pattern widened as the psi dropped until the entire chalk line was making contact with the pavement at 24 psi.
Old 03-16-2013, 11:47 AM
rickc309's Avatar
35 Toyo's are 12.5 wide, the Rubi wheels are 7.5.
Old 03-16-2013, 12:35 PM
kjeeper10's Avatar
Running a 12.5 on a 8" or in your case a 7.5" affects the contact patch.
It usually requires a lot less pressure to get full tread contact because the tires are ballooned to begin with.
Some tire shops won't even mount a 12.5 on a 8" because the manufacture doesn't recommended it.
9" or 10" for a 12.5"
I hear it from the only shop that will touch my tires.
"You are running the incorrect size wheel" he says.
Uses it as a excuse to not try and get a good balance on my tires.
BS actually :(
Old 03-16-2013, 03:27 PM
rickc309's Avatar
BS actually :(
The tire shop that installed mine didn't blink an eye, the Toyo's balanced out well with very little weight. I plan on some bead locks soon but the stock wheels will have to do for now.
Old 03-16-2013, 05:20 PM
CT_Buck's Avatar
Glad you like the setup. You got a pic of them Toyo's on the stock rim?
Old 03-16-2013, 05:53 PM
Ryan0260's Avatar
Are you measuring the air pressure when he tires are cold or warm? That number actually doesn't sound too far off. I run 35" trail grapplers on the stock wheels, and cold they are around 25-26.
Old 03-16-2013, 05:58 PM
rickc309's Avatar
Quick Reply: 35 Toyo MT's on stock wheels chalk test
