35" tires with crd engine
Anybody drive 35" tires with 4,1 gear and crd (diesel) engine? How its working (accelerating) without regearing? My jeep is still in garage so I can not test it personally. I will regain my jeep in 2 weeks :(( I could not wait for this moment!!!
Crd engine has 410 Nm torque at 2000 rpm (maybe I`ll make program tuning for extra 50-60 Nm torque), so I hope it will be enough...
One way or another, if somebody has some experience - please write!
And thank You Aussie! Probably You are right...
Hi Matias...If You have a CRD Rubicon I think that the problem you have is to run the 35" on daily use (road) and I think that 4.56 gear can be the right choise.
But...when you're O.R. if u put on the 4.56 with the Rubi T.case (4:1)is possible that the final gear ratio can be shorter than your wheeling style need.
