View Poll Results: Have you had problems due to 35s?
No
82
67.77%
Yes
10
8.26%
To soon to tell
29
23.97%
Voters: 121. You may not vote on this poll
35"s Problem Poll
Old 07-27-2008 | 06:11 AM
  #21
jkkat's Avatar
I votes to soon to tell, only 3 trips so far and about 6-800 miles. TF 2.5BB with no extra bump stops and Unlimited springs. Slight rubbing on fender frairs and pinch seam in back but fixed it.
Old 07-27-2008 | 08:45 AM
  #22
chuck45's Avatar
Originally Posted by DesertDJ
I also bought a Pro Comp Accu Pro and adjusted my speedo. The Accu Comp worked like a charm and my shifts are nice and crisp.
I did the same an it makes a huge difference. I don't know how well the stock shift points are dialed in; but what you end up with after installing 35/37's with or without gears is pretty lousy. To the list above (adj control arms, gears, and aftermarket driveshafts) I would add the AccuComp as necessary for an automatic. I should have added adjutable track bars to the list above too.
Old 07-27-2008 | 08:57 AM
  #23
AZJeeper's Avatar
Originally Posted by adgraybda
After reading about different problems due to tires & lift at different places i decided to make a poll where problems can be listed in one place!
33s are close enough to stock that problems i have seen are minimal, so for thoes with 35s, list any problems you have had!
Missing a key piece of the equation - what wheels and/or spacers are you using? Lift makes room, but wheel backspace is critical as well. I suspect a lot of "problems" are from ill-fitting wheels, not the lift or the 35" tires.
2 cents.
Old 07-27-2008 | 10:35 AM
  #24
robin's Avatar
Originally Posted by MaloCS
4" Rancho Sport and 35s. Lifts only been on for a few weeks and she hasn't been on the trail yet. We're going wheeling today so if there are any problems I should find out soon.
I have the same lift and 35s. amazing flex. no problems.
Old 07-27-2008 | 10:53 AM
  #25
TBJK's Avatar
I would agree too much backspacing will cause tire rubbing..listen to others word of wisdom. Like most say 4.25 bs is suggested,that seems to be the majority that i have seen around
Quick Reply: 35"s Problem Poll
