35 inch tires & aussie OR 37s open on dana 30
I have 34s rt now and need new tires this spring. I have dana 30 with sleeves gussets. Thinking either 37s or 35s and aussie. Already have arb in rear. What will perform better offroad? Which choice will cause more stress in dana 30?
JK-Forum Founder
if you're planning to install an aussie, i would stick with 35's and even with that, i would still recommend getting a set of chromoly shafts installed. 37's are a lot of tire for a 30 even open and i definitely wouldn't recommend it especially with an aussie.
JK-Forum Founder
i think the key words here are "so far". you don't need to give it hell to break things. more times than not, it the cumulative effect of wheeling that will cause something like an axle shaft to break and a lot times, when it finally goes, it'll be on something stupid easy. but, what do i know. all i can say is that i've been able to break chromo dana 44 shafts and even a dana 60 shaft and i'm not one to give it hell.
