34in Tires
sdhexpert - thanks for the reply and pics! Yeah, I don’t want to use spacers too.
Like dmarco1103 I’m probably going to have a smaller lift (I’ve read that OME usually give you more than 2-2.5”), so since you have slight rubbing with your larger lift maybe I’ll stick with 33”.
For 33” tires I’ve been looking at the BFG KMs LT255/85R16 - same width as the Rubi tires except 33” and obviously I would need to get new 16” wheels. On the plus side they are available at my local Discount Tire and run less than may other tires.
I’m thinking that since I will have a smaller lift I will have more rubbing - I don’t know how much more but some more. I’m sure that if I had any rubbing it would eventually get annoying to me and I would have to “fix it” - as you are thinking maybe the fix would be cheap.
I would really like to just use my current rims (to get the cheaper upgrade), and I would prefer to get something like the BFG KMs (which I really like), and I don’t really want a wider tire. The BFG KM 33” tires have the same tread, same width, but are 1” taller. Unfortunately they’re 16” instead of 17”. From my limited look at prices on-line the BFG KM 33” are a little over $100 cheaper than the TOYO 34’s. Not enough for new wheels, but a good start at it.
I would think that if the TOYOs rub with the stock rims then those would rub even more. I think that from what sdhexpert is saying the TOYOs rub because the tires are a little too wide with the stock rims (no change in the backspacing or no spacers).
Yes, I'm running with no spacers but I do have minor rubbing on the front at max turn. I just try not to crank the wheels when turning. I haven't looked close but I think I can fix it by adjusting the turning stops. To me this is an acceptable compromise instead of the spacers (just don't have a good feeling about) or having to purchase new rims. I may get new rims in the future, but for right now it is not that big of a problem.
Had to get a spacer (expedition one) for the spare tire rack, and now must deal with the 3rd light issue.
My question - where did you find the tires? I've been searching and the best I can find is treaddepot for $1450(for 5).
I think this is mostly a mid-atlantic company but STS tire carries Toyo. www.ststire.com, also check ebay, there are a few dealers on there.
