34in Tires
Old 03-20-2008 | 08:43 PM
dmarco1103's Avatar
Default 34in Tires
I have been trying to decide between 33 and 35in tires, but have recently found out that there is a 34in Goodyear MTR tire. Will these fit on an 08' rubi with a 2 1/2 bb. And does anyone have any experience with these tires, are they recommended?
Old 03-21-2008 | 08:32 AM
2K1TJ's Avatar
I ran that size (305/70/17) on a 2" BB without issue. Great setup. That size was Maxxis Bgihorns.
I'm now running the MTR's in 37x12.50x17's. So far they're great on road. Haven't had a chance to wheel them yet.
From what I've heard, they're a great tire except in heavy mud. Rotate them often to keep the wear even.
Old 03-21-2008 | 08:38 AM
JLightning9's Avatar
34" are also available in Interco Trxus MTs.
I have the 33's but my buddy has the 34's and loves them. Highly recommended. Check out my gallery for close ups of the tread.
Old 03-22-2008 | 08:24 PM
sdhexpert's Avatar
Look at the 285/75R17 MT TOYO ....... 34.1" tall, and recommended for 7.5" rims.
Old 03-22-2008 | 08:54 PM
joe002's Avatar
Sdhexpert - so you are running them on the stock wheels with no wheel spacers? Any rubbing? Like dmarco1103 I’m thinking of a 2 or 2.5 BB lift, and if these tires fit on the stock rims with no rubbing it sure makes the upgrade a bit cheaper!
Old 03-22-2008 | 09:46 PM
dmarco1103's Avatar
I'm not sure if they will fit on stock rims, i have different wheels which have a 4.5in backspace. I've been told that anything much more than that will cause rubbing and I think that the stock rims have around a 6.25in backspace. Although I may be wrong
Old 03-23-2008 | 05:33 AM
sdhexpert's Avatar
Yes, I'm running with no spacers but I do have minor rubbing on the front at max turn. I just try not to crank the wheels when turning. I haven't looked close but I think I can fix it by adjusting the turning stops. To me this is an acceptable compromise instead of the spacers (just don't have a good feeling about) or having to purchase new rims. I may get new rims in the future, but for right now it is not that big of a problem.
Had to get a spacer (expedition one) for the spare tire rack, and now must deal with the 3rd light issue.
Old 03-23-2008 | 08:54 AM
jkkat's Avatar
Every think about these? http://www.intercotire.com/site36.php
Last edited by Robar; 03-23-2008 at 09:54 AM. Reason: Please do not post direct non sponsor links.
Old 03-23-2008 | 09:19 AM
RevyJKU08's Avatar
No such size for a Toyo M/T:
it's either a 285/70R17 which 33x11.5R17 or 295/70R17 which is 33.5"x12R17.
Old 03-23-2008 | 09:53 AM
sdhexpert's Avatar
Default 285/75R17's w/ome lift
See the signature for details .....
