33s on a stock jeep
Old 07-16-2009 | 07:22 PM
the_cuse420's Avatar
Default 33s on a stock jeep
dose anyone know how high 33s will lift a stock x
Old 07-16-2009 | 07:25 PM
Default 33s on a stock x
dose anyone know high 33s will lift a stock x
Old 07-16-2009 | 07:26 PM
31 inch is a stock tire
33 equals plus 2 inched in eniter height but only 1 more inch of clearance since the tire will have an extra inch on each side
so 1 inch
Old 07-16-2009 | 07:28 PM
daggo66's Avatar
My stock X tires are 32".
Old 07-16-2009 | 07:29 PM
look at the one in the stock section if too lazy it will add a inch to each side so a inch of lift
Old 07-16-2009 | 07:30 PM
realy i think mine were closer to 31 idk its still only about an inch of lift tho
Old 07-16-2009 | 07:43 PM
nosmr2's Avatar
I had 33's on 16' wheels without a lift for a few days and it fit.
Old 07-16-2009 | 10:29 PM
adgraybda's Avatar
Not the best pic but 33s with no lift, i think there is a better pic in my gallery
Old 07-17-2009 | 05:51 AM
JYogi's Avatar
Enough that you shouldn't do it for a regular driver or wheeling.
If you are putting the tires on for a few days till you get your lift that is ok but if you plan on just running 33's and no lift you will have rubbing problems so it is not advised.
If you are doing it to gain the look of a lift that won't do it.... Its only going to be an inch taller...
Old 07-17-2009 | 05:54 AM
racer83l's Avatar
if the tires you are looking at are flotation.. as in the sidewall reads 33 x whatever...
they will fit. there more like 32" which is OEM
Quick Reply: 33s on a stock jeep
