33's no lift, articulation pics
anyone roll with no lift on 33's and getting good articulation? or are the 33's requiring a lift for any good articulation?
Dirt man that's pretty impressive. Almost makes me want to rethink the 2.5" spring kit I'm ready to pull the trigger on. I like the LCOG look. Humor me on this tho. Don't I need to create "space" between the top of my tire and the bottom of the fender to have decent articulation? Remember I'm new at this. I've been under the jeep and there's only a couple of inches of up travel per wheel till it hits the bump stop. In my mind this is telling me I have two inches of up travel. Down travel "droop" is unknown in my mind but I would guess it would be limited to the opposing wheels up travel which like I said appears to be 2 inches. School me if I'm wrong. According to the jeep in the pic I should be wrong. What am I missing? Obviously jeep in pic is disco'd. Is it running stock wheels no spacers or with spacers. I have 17x9 with 4.5" back spacing. Seems like I'd be eating fender if I tried this.
Yes, read his sticky... Here's a link in case you can't see his sig, very informative! https://www.jk-forum.com/forums/modi...-lifts-288269/
33s will be prety much the same as stock
this was mine brand new . They flex pretty well . Not as much as we prob would like but , my 33s are actually smaller than the stockers they are 31 3/4" Im not lifting mine, I prefer stock height . Im prob in the minority on that but i like it low . Id say it depends on what terrain you intend on driving on if its rough riding maybe a lift would be the way to go. For my use stock is good enough.
i know it will take me any where i had to go . might just take the scenic route if need be
this was mine brand new . They flex pretty well . Not as much as we prob would like but , my 33s are actually smaller than the stockers they are 31 3/4" Im not lifting mine, I prefer stock height . Im prob in the minority on that but i like it low . Id say it depends on what terrain you intend on driving on if its rough riding maybe a lift would be the way to go. For my use stock is good enough. i know it will take me any where i had to go . might just take the scenic route if need be
Tires, lockers, gears. You are getting tires now do lockers and lower gearing and you will tackle most trails. Rock crawling needs lots of articulation where as most trail riding require traction and torque for climbing steep grades. This is where having lockers and low gears will allow you to run these trails slower and under control. Adding lift to run trials that have lots of steep and off camber situations just makes you less stable and more likely to flop.
