33s and no lift
33s and no lift
How bad could I rub without a 2.5" lift with 33s? I was planning on getting a Tera Flex 2.5" with shocks and springs for my next purchase and then a winch. With all the gear talk I was thinking I should take the money for those two items and get gears. I have an auto with 3.73 and need to regear. I'm probably gonna go with 4.88s for better in town acceleration and to make the highway a little more bearable.
Depends on what you are going to do with your JK. You could probably run 33's without the lift if you're planning to mainly stay on the road. You'd get some rub in the wheel well potentially with sharp turns, but otherwise passable.
Since you're planning a lift and a winch, I assume you're thinking of off-roading it. In that case, once you disconnect the front swaybars you could damage the fender and wheel wells pretty good without the lift. Espcecially climbing rocks!
The tera-flex 2.5" is a decent budget lift...so again depending on what you're looking to do, might be worth the $.
Love the color of your JK...haven't seen too many of those around here...
I have 33s now with no lift. I didn't have any rubbing issues at all when driving on the street. I did rub when disconnected and flexed though. I just chopped my fenders like in WOL's write-up and now the problem is solved!
