33's with no lift
Old 12-25-2007 | 04:23 PM
IndianaJK's Avatar
Default 33's with no lift
Anyone running 285/75/16 tires with no lift?
I am getting 7189 Procomp wheels that are 16x8 with 4.5" backspace.
I have these 285/75/16 Nitto tires that I want to use. I think they are 11.5"
wide.
I want to see how far they will stick out past the wheel flare.
Will I have any rubbing issues without a lift?
Pictures please!!
I only have 400 miles on my new JK and don't want to lift it for a while.
Old 12-26-2007 | 05:34 AM
captsam54's Avatar
Default no lift 33's
Here is a pic of mine before I lifted her, running Nitto's 295's and Procomp 7089's... No back spacing.. You can't 4 wheel hard, or they will mess with the fender flares.(and knock them loose). Normal driving is fine.
Old 12-26-2007 | 06:32 AM
Wings fan's Avatar
I'm currently running 285/70/17 (which is the same overall size) with no lift and no rubbing off road. I think your problem would not be the tires but BS on your rims (4.5"). Mine are 5.75" and the problem you run into with out a lift is the rear tires don't tuck up into the fenders. Mine do but you don't get that cool look with the tires sticking out past the fenders.
Old 12-26-2007 | 08:22 AM
flakedog's Avatar
Here's a picture of mine before I put my lift on. Did not have any problems.
Old 12-26-2007 | 08:24 AM
HULKGREEN's Avatar
I had to use Spider trax wheel spacers with the stock rims because of backspacing of rim; but I finally lifted it and went to a rock crawling rim
Old 12-26-2007 | 09:59 AM
DirtyJeepJk's Avatar
i've been running 33's with no lift for a few months now and i haven't run into any serious issues. my Jeep is my daily driver that i wheel hard every chance i get. i have been slow in deciding what i want to do as far as lift goes and wheeling on stock suspension has really given me a better idea of what i need. off road i do rub the rear fenders when flexed but it's an easy and cheap fix ( replacement plastic rivets ).
Old 12-26-2007 | 07:49 PM
1leg's Avatar
255/85/16s 33.2 X 10.5 No lift
Quick Reply: 33's with no lift
