33's minimum lift with full flex/articulation
I'm hearing that 33's will rub a bit without a lift. Does anyone know what the minimum lift you can get away with and still have full flex/articulation. I want a bit bigger tires, but not at the expense of performance.
Thanks,
Thanks,
JK-Forum Founder
Actually, the only real rubbing you may get is up front due to the factory rake and you might be able to get by with just adding 3/4" spacers up there. Otherwise, I would recommend installing a 2" budget boost as this will definitely get you what you want and for cheap
JeepSWAG
Sponsoring Manufacturer
Thank you. That is what I needed to know. I have a great deal of competition for household funds if you know what I mean and need to keep cost down. I'll get my 33's and spacers and just wait to win lift on the 16th. All kidding aside, I appreciate your help.
