33s and bb 2 inch lift?
what do i have to do to do this set up,i want a bb lift that will take out the factory rake,will my speedometer be the same?anything w my navi need to be done? waht other things will i need to address? thanks
I think the Teraflex leveling kit would be perfect for you. It lifts the front 2", and the rear 1". And you can fit 33's easily. Your speedo will be off a little but going with the slightly larger tire (it will read slower than you are actually going).
The kit is very easy to install, and nothing else needs to be changed.
They may rub a tiny bit at full flex (My 32's never have, and I have flexed it to it's max). And you should be fine with stock wheels. Although wheel spacer will give you a better stance. And you may rub when turning at full lock with the wider tires. Unless you go with narrower 33's.
I would say your MYGIG nav isn't specific to just a JK, that they us the same one in all of the Chrysler vehicles and the tire size on the vehicle will have no effect on the nav whatsoever.
the only thing I would look at upgrading is to get a quick Disco's like JKS if you are planning on off-roading and doing some flexing. Also, if you are using stock rims get some spacers if you go wider than 12" 33's this will avoid rubbing lock to lock steering.
Your speedo will be out alittle bit depending on the size of tires that came stock on your JK.
A few pics with 2" lift
[IMG][/IMG]
