33's or 35's ???
Old 09-12-2011, 02:46 PM
jktoy's Avatar
If u had a 6spd. Then I would say go for the 35s. That's what I have and I have no problems with it. But having an auto if u r not wanting to regear than go with 33s.
Old 09-12-2011, 02:51 PM
azrwilkinson's Avatar
You dont have to sleeve and gusset right away with 35, just baby her around for a little while. Gearing, oh ya deffinatley do this, you'll wish you had if you dont. I have had 35 on for a year and a half now and done some serious trails, no bent c's yet....(looking for wood) Good luck with what ever you decide.
Old 09-12-2011, 02:53 PM
jeepjackal's Avatar
My plan is to upgrade to 37's, everyone in my area has 35's,
Old 09-12-2011, 03:29 PM
Ironside's Avatar
Thanks for the reply's! Keep em coming.
Old 09-12-2011, 03:46 PM
XBlacky08X's Avatar
35's for sure.. Don't waste your time/money with 33's.. Glad I didn't..
Old 09-12-2011, 03:48 PM
Ryan0260's Avatar
I think the fact you are even contemplating 35's should tell you your answer. If you get the 33's you will more than likely wish you had gone 35's. I run 35's on my jku with 4.10's and couldn't be happier. I will be going to 5.13's at some point but for now it is bearable. Just leave the overdrive off...
Old 09-12-2011, 03:58 PM
jeepfan's Avatar
There is always the option of the in-between 33-35. A few mfg's make a 295/70R17 or 305/70R17. Toyo M/T, Cooper STT, BFG KM2 (new size 305/70R17). These measure out about 33.5-33.8 and usually can be run on an unlifted/small lifted JK even without spacers if using stock wheels.
There is a good thread on these..https://www.jk-forum.com/forums/show...res-Badass-IMO
I just ordered a set of the Toyo 295/70R17 tires and a TeraFlex Leveling Kit. Just decided I didn't want to run 35's on this Jeep and keeping the lift lower. AND I am trying to keep the mileage up.
Old 09-12-2011, 04:09 PM
Ironside's Avatar
Im loving this! Keep them coming! My Heart is set on 35's with either 2.5 or 3" coil lift. I know the 33's will be fine. Just think the JKU sits better on 35's.
Old 09-12-2011, 04:17 PM
jason0341's Avatar
Just do it. 2011 4sp auto, 35" Duratracs with 3.73. Fine for me, I run with OD off.
jeepmedic's Avatar
if you are looking for gearing info...every little bit helps....check it out !
This is probably the best write up / info I have found on the site.
https://www.jk-forum.com/forums/show...?82262-Gearing
