33's for 18" stockers?
Old 12-18-2007 | 06:49 PM
robs07sahara's Avatar
Default 33's for 18" stockers?
will i be able to run 33"s on my stock 18"s with a 2" spacer lift on my 07 2dr sahara.
Old 12-18-2007 | 06:51 PM
FRDesign's Avatar
Yep, Should Work fine as long as the tires aren't wider than 12.5"
Old 12-18-2007 | 06:54 PM
are you sure of an exact tire size for an 18" rim that i should look for that is
equivalent to a 33"?
Old 12-18-2007 | 06:59 PM
NE Wrangling's Avatar
I beleive 285
Old 12-18-2007 | 07:21 PM
mobotix's Avatar
275/70/18 will give you a 33" overall diameter. I wouldn't go wider than that on the stock 7.5" wide wheels.
Old 12-18-2007 | 07:23 PM
who makes a tire of that size.
Old 12-18-2007 | 09:02 PM
TheSimianCell's Avatar
You're fine. I would suggest you go with a hub centric spacer like Spidertrax as opposed to a lug centric spacer. I'm running a Tera BB w/ Toyo Open Country M/T's 33x12.5 18R and Spidertrax spacers
Old 12-18-2007 | 09:20 PM
Careful of the tire extending past the wheel well as in Mass you fail inspection. I cannot use spacer without sticking out if I upgrade width of tire. I run the 255/75/17 right now and I'm playing around on getting someone's 33" after they move up to 35". Used market is just weak at this point and so are funds as I've just order 1000 bucks in mods.
Old 12-20-2007 | 08:10 PM
codcape's Avatar
Default Stock Rubi Wheels with 35's??
Hi I have a Rubi Unlimited on order and want to install a lift and keep the stock wheels with 35's I like the look and I'm not a fan of the after market rims. I think the tire size would be...(305 70r 18)? , can you tell me what I would have to do? Lift size spacers etc.??
Thanks Again..Rick
