33" tires no regearing vs 35" tires with regearing
#21
Dude, I'd go with 33s and a nominal 2" lift. While home last week I saw a 4 door with just enough lift to look good with 33s and thought how practical it was for a DD and on road use. A huge improvement of looks over stock. Best bang for the buck in my book.
I went a little further with my 2 door but it is just a toy.
![Blush](https://www.jk-forum.com/forums/images/smilies/blush.gif)
#22
I have the 6 speed with 4.10 and my wife has the auto with 3.23. There is a huge difference. I run 33's and and she has 32's. Her Sahara struggles on the some of the trails while my Unlimited has plenty of power to go over the same obstacles. If you go to 33's, you will notice a big decrease in climbing power with your auto trans and the gears that you have.
#23
You may want to look at some new rims with a smaller backspace in a 16" or 17" They will eliminate the spacers and will run about the same money. 18" tires are quite a bit more expensive than 16" and you will have many more options over the 18".
Flat fenders like the zeon or bushwackers will give you an aggressive lifted look or you could trim you existing fenders to open up that wheel well.
Love the Rugged Ridge hyper silver wheels with 4.5 BS. Would look sharp on a Deep Water Blue.
Trying to pick between 11.5 and 12.5 width. Don't want it to stick out too much from the fenders.
![Question](https://www.jk-forum.com/forums/images/smilies/question.gif)
#26
I put 33's on my 2011 Rubi Unlimited and a 2.5 Teraflex lift. It still rides great and the gearing does not need to be changed. I still get decent MPG and for the type of off-roading that I do, this rig is perfect. I had 35's on my 09 and regeared to 4:88's and watched the fuel drop from around 14 to 9. Also, the 2K investment in gears, etc. Nothing wrong with doing that if you use the rig for some serious off-offroading, but I found I did not need everything I had done and was convinced I would not do it on my new one. Good luck with whatever you decide.
#27
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
