33" tires no regearing vs 35" tires with regearing
Old 11-07-2010, 09:12 AM
Crasher's Avatar
Unless you intend to do serious wheeling, the 33s would be the best choice. As mentioned, fewer expensive mods are needed and better economy. I have 33s on my ZJ and it will go anywhere a 35 will go. I have 34s on my JK and was wanting to go to 37s, but I don't have any trouble following Jeeps with larger tires (sometimes I have to take a different line) and the cost to get 37s is more lift, flat fenders, driveshafts and gears, plus the tires. Like your case, the end result would a Jeep that was less efficient, and harder to get in and out of. In many cases, smaller is better.
Old 11-08-2010, 01:03 PM
oriffx's Avatar
Default Thinking 33s
Great advice all around. But since I don't do a ton of off-roading ( I even have car seats in the back sometime), I'm probably sticking with 33s. So after much (probably too much) thought, here's my combo....
33" Mickey Thompson MTZs, Spidertrax wheelspacers, and Teraflex leveling kit.
Nothing crazy or over the top but definitely more aggressive.
Any thoughts?
Old 11-08-2010, 01:34 PM
RevyJKU08's Avatar
Any thoughts?
Nope...nothing wrong with that. I went with 33's and was very happy with my choice for my family's DD and weekend warrior! I am taking the next step and getting 35's for my next set so...I will see if I need to regear with 3:73 and 6spd and get compliants from my wife and 2 kids about the difficulty getting into the jeep.
One thing I would add on your list is front Quick Disconnects to your list...it makes a world of difference having the front swaybar disco'ed when your off-roading!
Old 01-19-2011, 07:31 PM
schwarzrb's Avatar
Can you post some pics of your ride? Looking to do the same setup for my '08. Thanks!
Old 01-19-2011, 07:38 PM
sringer's Avatar
I got 2.5 teraflex bb I didn't re gear and I'm running bfg km2 35x12.50x17
ID:	119595   Click image for larger version
ID:	119596   Click image for larger version
Old 01-19-2011, 07:46 PM
gunbo75's Avatar
i am running 34/10.5 /17 toyo mt with a auto 373 rear no problem
Old 01-19-2011, 08:06 PM
mostlystock's Avatar
...I don't do a ton of off-roading ( I even have car seats in the back sometime), I'm probably sticking with 33s. So after much (probably too much) thought, here's my combo....33" Mickey Thompson MTZs, Spidertrax wheelspacers, and Teraflex leveling kit. Nothing crazy or over the top but definitely more aggressive...Any thoughts?
Yeah: Good choice. Like you, I've got a 4-door, 90% daily driver, 10% offroad, want agressive but not over the top, etc. Settled on 32's with 16" rims and the TeraFlex leveling kit. I have 6-speed with 4.10 gears, so it's a little more tolerable. I think 33's would be my ideal tire size with this setup in terms of looks, but I'll sacrifice a little performance, and besides I'm not ready to spend the $ on 33's when my 32's are this new.... Also tow a 3,300 lb. trailer here on occasion so 32's are easier on the powertrain and gearing. I think the combination of the TF leveling kit plus 33's would give you a great combination of mild aggressive look, off-road performance for mild wheeling, and decent fuel economy and power for your gearing. I suspect that's about as far as you would want to go with your setup without regearing (fun, but can of costly worms). It will be on the edge, I think, but it won't suck by any means, and will probably satisfy your needs in most areas. And it should look decent.
Old 01-19-2011, 08:38 PM
mjm
mjm's Avatar
I'm pretty sure you will get a 50/50 split vote from a performance standpoint. I would go with what is pleasing to your eye. IMO 35's look the best because the JKU is so big. Go to the show & tell page and look up the show your 33's & 35's threads and compare. Don't look at the 37's....... If you have the budget go 35's, 33's are the gateway drug.
Old 01-19-2011, 09:12 PM
sringer's Avatar
Hahaha that's soo true. I skipped the "weed" (gateway) and went straight for the "cocaine" 35's super happy. No regrets here. Still runs great
Old 01-19-2011, 09:23 PM
RevyJKU08's Avatar
Here you go a few snap shots.
Quick Reply: 33" tires no regearing vs 35" tires with regearing
