33" tire, 7" stock rim
I want to get 33" DuraTrac's but wanted to save money by using my stock rims, I have the 16" x 7" inch rims and they apparently dont make them to fit. The smallest rim width I can find for 33's is 7.5". does anyone know of any 33" tire i can get to fit on a 16"x7" rim? or am I sol...
I have ran 35 12.50 on a a 15x7, however I did not air them down because I was afraid of it breaking the bead. Also you could try a 285x75r16 the only issue you may run into is it rubbing at full turn but there are other posts that show how to limit the turn stop. Hope it helps
I have heard that running a larger tire on the narrow rim is less likely to bust a bead when aired down. Some here are running 12.5's on stock rims. Do a couple of searches and draw your own opinion but I'm going to give it a try.
Tires are one the most important parts of an offroad vehicle. They truly are where the rubber meets road.
If you have done your research and believe the Duratracs fit your needs, then IMO you shouldn't compromise your choice so easily.
If you need a 7.5" wheel, check your local area for a set of cheap 17" Rubi "take offs".
That will allow you to go up a 12.5" wide tire.
