33 Duratracs - Speedo Still Correct
Old 01-29-2011, 06:44 PM
Tails's Avatar
I guess you're lucky. I swapped the stock 225/75/16 tires for 255/85/16 Coopers. These are said to be 33", I don't know how big they are in reality. It sure is a much bigger step getting in!
Now, when I am going 60 MPH on the speedo it's 68 in reality (according to my Garmin Nuvi GPS). That's a little too much for me. The police are really looking for people speeding where I live, so I just ordered an AEV Procal from Northridge to correct the situation.
By the way, tire noise has increased quite a bit even though these are A/T tires, and mileage has gone down a lot (from 18 to 14 MPG). We'll see what the MPG indicator in the dash says after correction.
Old 01-29-2011, 09:23 PM
TCORUM's Avatar
Originally Posted by Hawnted
Are you near sea level? I do not think I could stand it. The jeep is pretty slow stock compared to the pickup trucks I have driven in the past, which is fine, I knew it going in. When I put on 33 Duratracs, it got worse. I can only imagine if they were 35 how bad it would be. I do not think I could do it without regearing immediately. I am actually a little disappointed that I do not need a ProCal, now I realize that it was actually as bad as I thought. For 2 days I was thinking that I was going 75 when it read 72 or so...
central texas but i'm also in the hill country and still its not that bad for me. last truck i had was a nissan frontier 4.0L nismo and it was balls to the wall with 33's. going into the JK i knew it had a lot less power but i also dont expect nor drive them to drive the same. i really think it comes down to driving style. if someone is heavy on the gas all the time they are going to think its a dog but if your not then you may think the power is fair. just a thought.
Old 01-30-2011, 06:31 AM
mpro26's Avatar
I just put 305/65/17's on the jeep this weekend, so I need to get my GPS out and see how far off my speedo is now. I plan on going with different gears very soon, so I will be ordering the ProCal soon. Just from driving the jeep last night on I-95, the speedo doesnt seem to be off too much. Guess I will find out soon enough.
Old 01-30-2011, 06:35 AM
Hawnted's Avatar
Do you change the shift points manually? Or is it calculated based on gear height?
If my speedo is correct does the ProCal do anything for me?
Old 01-30-2011, 06:51 AM
Adam3612's Avatar
For what its worth when I put the 33" Duratracs on (275/70/18) then recalibrated something felt off, I measured them then tried again and it still feels off. I've used both a superchips and a procal to do this, even tried a different measurement. When I use my girlfriends Garmin Nuvi it shows im out 3 - 6 km/h, I trust the GPS because its been dead on in her car, my other car and every other vehicle its ever been used in.
Old 02-02-2011, 10:21 AM
Tails's Avatar
Just an update for those interested.
I received my AEV Procal yesterday and programmed it to make my TPMS warning light and chime go away, and to calibrate the speedometer.
So I went from stock 225/75/16 tires to 255/85/16 Coopers. Without measuring them, I just assumed they woud be around 32.5", so I entered that on the Procal.
Tested today with my Garmin Nuvi GPS and the actual speed is one mile below what is indicated on the speedo. So when I see 60 MPH I'm going 59 and when I see 70 MPH I'm going 69. That's perfect for me.
Note that the Jeep doesn't feel any different. The AEV Procal isn't a tuning device.
Quick Reply: 33 Duratracs - Speedo Still Correct
