325/60 R18 maybe?
325/60 R18 maybe?
Hi I'm Joe. Just traded my dodge dart for a 2013 jeep Sport. I have the opportunity to get a great price on some 325/60 R18 wheels and tires and was wondering if they fit with no lift or spacers. I've been trying to read a lot about fitment and it seems it might be to big. I can't find the BS info on the tires though so no idea. They're Khumo Road Venture.
If they're the all terrain, according to tirerack that's 33.3x13". You will need wheels with 4.5" backspacjng or less. you should be fine on road, but you may rub offroad a bit. Cut flares or a 1.5-2.5" lift would take care of it. I run cut flares and 2.5" teraflex budget boost with 35's.
I don't know what you mean by 10 lug universal. If you can send me a link to the wheel specs i can help you out. As long as you have a wheel with 5x5 (5x127mm) bolt pattern and backspacing of 4.5" or less you'll be fine. If the backspacing is indeed 5", you can either add a small 1/2" spacer or just adjust your steering stops. Hope that helps
