315/75 R16 on stock steel wheels
Has anyone run 315/75 r 16 (34.8's) one stock steel wheels with spacers? Im really not into spending money on aftermarket wheels, that’s why I’m running my Moab’s with my 35x12.50 R17 now. It seams that the price of R17 has shot up about 500 buck since I got my last set. Ill be going in to get a new 4 door JK soon and If I can run the 315/75 R16's on the stock 16" steel wheels I would like to try and nock some cost of the new jeep and the Tires I would be getting soon after.
Thanks
Nate
ps Pictures would be great too.
Thanks
Nate
Here you go, and personally I run 31 psi in front and 28 in the rear. You can play around with it but that is so far the best I have gotten for the tires to wear right. Off road on rocks I run 12 psi and I've dropped it as low as 8 psi in the sand and no problems
You will be fine then running 315s on the stock 16s i have had mine on for a while and they are great. i eventually want new rims but i want/ need 37's so i don't want to get new rims until i figure out what im going to do.
They'll "fit" but they won't wear right on road. To get the all the tread to contact the road you'll have to run pretty low pressures. That will cost you tire wear and handling, as well as MPG. I have 8" wide wheels with my 315's and I run 28 PSI on road. The 7.25" steelies will require even lower pressures to touch the road.
Saving money by burning up tires and fuel doesn't make sense to me.
Thanks
Nate
Thanks
Nate
-Greg
